[Qgis-user] How to calculate the transformation parameters for the QGIS Affine Plugin
sebastiano.lora
sebastiano.lora at gmail.com
Wed Oct 8 06:32:05 PDT 2014
Hallo Marcel,
have you tried to run the grass command v.transform with point file from the
Processing Panel?
In this way you do not need to calculate the parameters, and you can use it
for batch processing too.
You still need more than two points with known coordinates.
ciao
Sebastiano
Deutsches Archäologisches Institut | Orient-Abteilung
TAYMA Project
View this message in context: http://osgeo-org.1560.x6.nabble.com/How-to-calculate-the-transformation-parameters-for-the-QGIS-Affine-Plugin-tp5166345p5166493.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
