[Qgis-user] QGIS Server does not publish Oracle Spatial Layer
Richard Duivenvoorde
rdmailings at duif.net
Thu Oct 16 03:01:15 PDT 2014
On 16-10-14 10:17, Niemeier, Stefan (Stadtwerke Lemgo GmbH) wrote:
> Hi Richard,
> i cannot load the layer in QGIS because the layer node is not available in the xml.
> Which version of the qgis-dev should I install. The full-dev or the normal dev version?
> What version of QGIS Server I have to install? There is only one in the OSGeo4W Setup.
Hi Stefan,
(pulling it to the list again)
My setup here is a custom one: an standalone Apache install on Windows
(because the Apache from osgeo4w is an old version with known security
issues according to the sysadmins here).
As a test I installed qgis-dev package from osgeo4w, and copied ALL from
<osgeoinstall>\apps\qgis-dev\bin
and
<osgeoinstall>\bin
into the excisting cgi-bin directory of my Apache install and ran
QGIS-server as cgi(!)
I run it as cgi because I'm only testing, AND because a cgi is easier
for that: no need to restart apache because the environment/projectfile
is read for every request
Which makes me think: did you already restart your apache?
I see that the default QGIS-Server installed with osgeo4w is indeed
2.4.0-1. So I think with next release (within a couple of weeks you will
have 2.6.0.
Either wait for that, OR try to copy my setup to see if that helps?
Or issue a feature request to make QGIS-Server-dev also part of osgeo4w?
Regards,
