[Qgis-user] using QGIS with Java 7?
Richard Welty
rwelty at averillpark.net
Thu Oct 16 03:44:14 PDT 2014
On 10/15/14 10:55 PM, William Kyngesburye wrote:
> This is a side effect of the MDB driver in the GDAL framework. It requires Java 6 because I thought it the simplest - the use of Java 6 triggers the system to want to install it, which it can do automatically from Apple. Java 7+ is a separate, non-automatic, download & install from Oracle, and from the developer side more confusing to compile a binary for. Java 6 is safe fro your system and should not confuse other software that will take advantage of more recent Java versions installed.
> It's mentioned in the GDAL framework readme, but not directly in the GDAL Complete readme, so it's been catching people off guard. I plan to make the MDB driver into a GDAL plugin so a basic GDAL install doesn't trigger the surprise.
interestingly i never did install Java 6, but retried the QGIS installer
one more time and it installed anyway with Java 7. no idea why.
richard
Averill Park Networking - GIS & IT Consulting
OpenStreetMap - PostgreSQL - Linux
Java - Web Applications - Search
