[Qgis-user] loading layer style makes style invisible on canvas
Junior Delaz
delazj at gmail.com
Mon Oct 20 13:12:06 PDT 2014
hi,
the italic text just reminds you the latest field (or expression) used in
the drop down menu to apply a style.
Regards,
Harrissou
2014-10-19 15:42 GMT+02:00 Jake Maier <j.m at jmforestry.com>:
> Who can tell me please what a field in italics in the drop down menu for
> column in the style tab means.
> Thank you.
> Jake
> -----Original Message-----
> From: qgis-user-bounces at lists.osgeo.org
> [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Ramon Andiñach
> Sent: Friday, October 17, 2014 8:05 PM
> To: qgis-user List
> Subject: Re: [Qgis-user] loading layer style makes style invisible on
> canvas
> On 18/10/2014, at 05:29 , Jake Maier wrote:
> > Hi Everybody
> > First of all, thank you all participants for this vital and first class
> listserv.
> > I have a problem that looks like a bug but is so basic that I can’t
> imagine that it’s broken.
> > I have a joined layer of soils with the soil attributes in the joined
> database. I also have a saved style for wetness classes.
> > When I classify the layer before I load the style sheet, I can display
> all the wetness classes with a random style attributed to each class and
> display the layer on the canvas.
> > When I load the style for that layer and apply, nothing displays on the
> canvas even so I see the styles attributed correctly in the layer property
> window.
> > I have no clue what may be the problem.
> > Thanks for your help
> > Jake
> Hi Jake,
> Could you check the field that the style apples to?
> (Because it sounds a lot like when I apply my saved style that works on the
> "Au_ppb" field to a layer with an "Auppb" field)
> Also, is the field you're classifying is in the joined table?
> Did the join work as expected?
> And, is this in QGIS 2.4?
> -ramon
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20141020/edd0a32c/attachment.html>
