[Qgis-user] loading layer style makes style invisible on canvas
Jake Maier
j.m at jmforestry.com
Sun Oct 19 06:42:42 PDT 2014
Who can tell me please what a field in italics in the drop down menu for
column in the style tab means.
Thank you.
Jake
-----Original Message-----
[mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Ramon Andiñach
Sent: Friday, October 17, 2014 8:05 PM
To: qgis-user List
Subject: Re: [Qgis-user] loading layer style makes style invisible on canvas
On 18/10/2014, at 05:29 , Jake Maier wrote:
> Hi Everybody
> First of all, thank you all participants for this vital and first class
listserv.
> I have a problem that looks like a bug but is so basic that I cant
imagine that its broken.
> I have a joined layer of soils with the soil attributes in the joined
database. I also have a saved style for wetness classes.
> When I classify the layer before I load the style sheet, I can display
all the wetness classes with a random style attributed to each class and
display the layer on the canvas.
> When I load the style for that layer and apply, nothing displays on the
canvas even so I see the styles attributed correctly in the layer property
window.
> I have no clue what may be the problem.
> Thanks for your help
> Jake
Hi Jake,
Could you check the field that the style apples to?
(Because it sounds a lot like when I apply my saved style that works on the
"Au_ppb" field to a layer with an "Auppb" field)
Also, is the field you're classifying is in the joined table?
Did the join work as expected?
And, is this in QGIS 2.4?
-ramon
Qgis-user mailing list
Qgis-user at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-user
