[Qgis-user] Project files manager
    Luigi Pirelli
    luipir at gmail.com
    Fri Oct 31 03:01:18 PDT 2014
Hi Patricio,
I don't know a plugin doing what you need... similar plugin are
QConsolidate and PortableProject. None of them save the project in a
DB, but they can be upgraded to do what you want.
I should notice that QConsolidate is done by Alex Bruy that is one of
the most active QGIS hacker... so if you need a customization is
simple to do the right choice. For other customizations you can ask to
me ;)
Regards Luigi Pirelli
On 31 October 2014 10:11, Patricio Soriano <pasoriano at gmail.com> wrote:
> Hi everyone ( and sorry for my english )
> I'm looking for if there, is a plugin you can use to manage projects in
> QGIS.
> The idea is to save the file in QGS a database (PostGIS or SpatiaLite or a
> no-geographical database) . For example , to start QGIS it could open the
> QGIS project database table and load one . Similarly , you could save a
> newly created project.
> Thx
> Hola a todos
> Estoy buscando, si lo hay, un plugin para gestionar proyectos en QGIS. La
> idea es guardar los archivos qgs en una base de datos (PostGIS o SpatiaLite
> o no geográfica). Por ejemplo , al iniciar QGIS , se podría abrir el
> proyecto de QGIS desde la tabla de la base de datos y cargar uno . Del mismo
> modo, se podría guardar un nuevo proyecto creado.
> Gracias
> Patricio J. Soriano Castro
> +34 639714412
> www.sigdeletras.com :: @sigdeletras :: Linkedin
> Qgis-user mailing list
