[Qgis-user] Project files manager
    Patricio Soriano
    pasoriano at gmail.com
    Fri Oct 31 03:29:59 PDT 2014
Thanks for the links Luigi. I think these extensions are very useful.
What I'm looking for is something like the ability to save the layer
styles from properties of the layer .
I'll keep looking .... or I'll have to learn to program  ;-)
El 31/10/14 a las #4, Luigi Pirelli escribió:
> Hi Patricio,
> I don't know a plugin doing what you need... similar plugin are
> QConsolidate and PortableProject. None of them save the project in a
> DB, but they can be upgraded to do what you want.
> I should notice that QConsolidate is done by Alex Bruy that is one of
> the most active QGIS hacker... so if you need a customization is
> simple to do the right choice. For other customizations you can ask to
> me ;)
> Regards Luigi Pirelli
> On 31 October 2014 10:11, Patricio Soriano <pasoriano at gmail.com> wrote:
>> Hi everyone ( and sorry for my english )
>> I'm looking for if there, is a plugin you can use to manage projects in
>> QGIS.
>> The idea is to save the file in QGS a database (PostGIS or SpatiaLite or a
>> no-geographical database) . For example , to start QGIS it could open the
>> QGIS project database table and load one . Similarly , you could save a
>> newly created project.
>> Thx
>> Hola a todos
>> Estoy buscando, si lo hay, un plugin para gestionar proyectos en QGIS. La
>> idea es guardar los archivos qgs en una base de datos (PostGIS o SpatiaLite
>> o no geográfica). Por ejemplo , al iniciar QGIS , se podría abrir el
>> proyecto de QGIS desde la tabla de la base de datos y cargar uno . Del mismo
>> modo, se podría guardar un nuevo proyecto creado.
>> Gracias
>> Patricio J. Soriano Castro
>> +34 639714412
>> www.sigdeletras.com :: @sigdeletras :: Linkedin
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
*Patricio J. Soriano Castro*
+34 639714412
www.sigdeletras.com <http://www.sigdeletras.com> :: @sigdeletras
<https://twitter.com/sigdeletras> :: Linkedin
<https://www.linkedin.com/in/patriciosorianocastro>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20141031/751e77fc/attachment.html>
