[Qgis-user] QGIS curve looking lines not viewable
    Explorer
    shoonyathaa at gmail.com
    Fri Oct 31 18:57:52 PDT 2014
Thanks for the response. Is there any other way to convert the existing
Oracle data type to something else which can then be rendered in QGIS?
   Curious, curves are quite common in map data, so how does all others use
QGIS then ?!
Thanks for your time.
On Fri, Oct 31, 2014 at 5:58 PM, Andreas Neumann [via OSGeo.org] <
ml-node+s1560n5170525h30 at n6.nabble.com> wrote:
> Hi,
> Curves (circular arcs) are not yet supported in QGIS.
> There is an ongoing development to implement curves for display and
> editing, but in its first incarnation it will only support Postgis data
> sources. There may also be support for GML/WFS (but I am not sure). The
> plan is to release it in either 2.8 or 2.10.
> If you have interest in curve support in other data formats (Oracle, SQL
> server, dxf, etc.) you are very welcome to support/sponsor the effort.
> Andreas
> On 31.10.2014 05:35, Explorer wrote:
> > Hi,
> >     New to QGIS and trying to make it work with our Oracle data.
> Currently
> > using QGIS v2.4
> > When viewing some polylines(Oracle datatype 2002) which are looking like
> > curves, I don't see that displayed in QGIS.
> > The rendering is like this and I did disable the "Simplify geometry" in
> > layer properties' rendering menu.
> http://osgeo-org.1560.x6.nabble.com/file/n5170519/QGIS_Missing_Curve1.png>
> > *Curved line visible from the same Oracle data viewed in MapGuide Open
> > Source*
> http://osgeo-org.1560.x6.nabble.com/file/n5170519/MGOS_PolyLine_As_Curve_Visible.png>
> > Any suggestions or assistance in rendering?
> > Thanks for your help.
> > View this message in context:
> http://osgeo-org.1560.x6.nabble.com/QGIS-curve-looking-lines-not-viewable-tp5170519.html
> > Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> > Qgis-user mailing list
> > [hidden email] <http://user/SendEmail.jtp?type=node&node=5170525&i=0>
> > http://lists.osgeo.org/mailman/listinfo/qgis-user
> [hidden email] <http://user/SendEmail.jtp?type=node&node=5170525&i=1>
>  If you reply to this email, your message will be added to the discussion
> below:
> http://osgeo-org.1560.x6.nabble.com/QGIS-curve-looking-lines-not-viewable-tp5170519p5170525.html
>  To unsubscribe from QGIS curve looking lines not viewable, click here
> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=5170519&code=c2hvb255YXRoYWFAZ21haWwuY29tfDUxNzA1MTl8Nzc3MTQ1MTg=>
> NAML
> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
View this message in context: http://osgeo-org.1560.x6.nabble.com/QGIS-curve-looking-lines-not-viewable-tp5170519p5170710.html
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20141031/ee94dba0/attachment.html>
