[Qgis-user] Labels not visible when setting them programmatically.
Werner Macho werner.macho at gmail.com
Wed Apr 1 04:42:39 PDT 2015
does
https://github.com/mach0/qchainage/blob/master/chainagetool.py
line 150 ff help you?
regards
Werner
On Wed, Apr 1, 2015 at 1:25 PM, Casper Børgesen (CABO) <CABO at niras.dk> wrote:
> I’m trying to programmatically set and enable labelling on a layer using
> Python in QGis 2.9.0.
>         label = QgsPalLayerSettings()
>         label.readFromLayer(myLayer)
>         label.enabled = True
>         label.fieldName = 'myField'
>         # Just to change something clearly visible.
>         label.textColor = QColor(255,0,0,255)
>         label.writeToLayer(myLayer)
> This doesn’t enable labelling, but if I enter the Layer Properties on
> myLayer, everything looks okay and when pressing Apply, the labels become
> visible.
> Is there something I need to set to avoid having to manually click Apply to
> get the labels visible?
> Calling iface.mapCanvas().refresh() afterwards doesn’t work.
> Regards, Casper
> Qgis-user mailing list
