[Qgis-user] Labels not visible when setting them programmatically.
Casper Børgesen (CABO)
CABO at NIRAS.DK
Wed Apr 1 04:48:16 PDT 2015
Hi Werner
Sadly no, it does not.
Regards, Casper
-----Original Message-----
From: Werner Macho [mailto:werner.macho at gmail.com]
Sent: 1. april 2015 13:43
To: Casper Børgesen (CABO)
Cc: qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] Labels not visible when setting them programmatically.
does
https://github.com/mach0/qchainage/blob/master/chainagetool.py
line 150 ff help you?
regards
Werner
On Wed, Apr 1, 2015 at 1:25 PM, Casper Børgesen (CABO) <CABO at niras.dk> wrote:
> I’m trying to programmatically set and enable labelling on a layer
> using Python in QGis 2.9.0.
> label = QgsPalLayerSettings()
> label.readFromLayer(myLayer)
> label.enabled = True
> label.fieldName = 'myField'
> # Just to change something clearly visible.
> label.textColor = QColor(255,0,0,255)
> label.writeToLayer(myLayer)
> This doesn’t enable labelling, but if I enter the Layer Properties on
> myLayer, everything looks okay and when pressing Apply, the labels
> become visible.
> Is there something I need to set to avoid having to manually click
> Apply to get the labels visible?
> Calling iface.mapCanvas().refresh() afterwards doesn’t work.
> Regards, Casper
> Qgis-user mailing list
