[Qgis-user] Batch Processing
Nicolas Cadieux
nicolas.cadieux at archeotec.ca
Fri Apr 3 11:34:23 PDT 2015
The best way to do batch processing is with python and Qgis. Fortunately, for those who don't know python, you can use the Qgis processing toolbox plugin to automate many algorithms (right click on the algorithm). If you want to make something more complex, you can use that plugin to create a model that will link a series of algorithms together.
You would get more help if you add exactly what you want to do with the .shp.
Good luck.
Nicolas Cadieux M.Sc.
Les Entreprises Archéotec inc.
8548, rue Saint-Denis Montréal H2P 2H2
Téléphone: 514.381.5112 Fax: 514.381.4995
www.archeotec.ca
Le 2015-04-02 22:53, "Surya Pratap [via OSGeo.org]" <ml-node+s1560n5196683h34 at n6.nabble.com> a écrit :
Hi, I have a set of shapefiles on which I want to do some experimental analysis. since the same actions need to be done on each file, I thought batch process may be the place to go. The issue is for each run I need to select the files and set values in the batch. Is there a way to save and edit the batch files and then load it? Regards Surya
Qgis-user mailing list
[hidden email]
http://lists.osgeo.org/mailman/listinfo/qgis-user
If you reply to this email, your message will be added to the discussion below:
http://osgeo-org.1560.x6.nabble.com/Batch-Processing-tp5196683.html
To start a new topic under Quantum GIS - User, email ml-node+s1560n4125267h38@n6.nabble.com
To unsubscribe from Quantum GIS - User, click here .
NAML
View this message in context: http://osgeo-org.1560.x6.nabble.com/Batch-Processing-tp5196683p5199934.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150403/2eed69b3/attachment.html>
