[Qgis-user] Batch Processing
Surya Pratap
pratap.surya at gmail.com
Thu Apr 2 19:54:13 PDT 2015
I have a set of shapefiles on which I want to do some experimental
analysis. since the same actions need to be done on each file, I thought
batch process may be the place to go. The issue is for each run I need to
select the files and set values in the batch.
Is there a way to save and edit the batch files and then load it?
Regards
Surya
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150403/d28d9a5f/attachment.html>
