[Qgis-user] drawing circles in Qgis2,8
Peter Aherne
peterfaherne at gmail.com
Wed Apr 8 02:45:24 PDT 2015
Thanks for all the suggestions about this problem. I am now facing the
problem that when I try to upload the sites through the add repository
button I get a message that the network has timed out. I've tried this
in several locations using different WiFi services so I'm wondering if
there is either a problem with my laptop or a general problem with
Qgis 2.8? Any advice please?
On 4/6/15, coder.tuxfamily <coder at tuxfamily.org> wrote:
> Hi,
> RectanglesOvalsDigitizing aren't maintend I did a fork named CADDigitize
> which works with polygon or polyline.
> Also there is more tools (and more next months).
> Regards.
> Le 06.04.2015 00:19, Carlos Carbajal a écrit :
>> Hi Peter,
>> The recommended plugin (Rectangles ovals Digitizing)only works when
>> the geometry is a polygon. My suggestion is generating a buffer to the
>> points
>> regards,
>> Carlos Carbajal
>> El 05/04/2015 a las 16:22, Peter Aherne escribió:
>>> Thanks for these suggestions, however, my plugin section informs me
>>> that these are unavailable. I have the feeling that there is either a
>>> problem with my qgis or with 2.8 in particular. Any ideas,please?
>>> On 4/5/15, Alexandre Neto<senhor.neto at gmail.com> wrote:
>>>> Try this:
>>>> http://anitagraser.com/2011/10/21/easy-rectangles-circles-and-ellipses-in-qgis/
>>>> Best regards,
>>>> Alexandre Neto
>>>> Em 05/04/2015 10:30, "Peter Aherne"<peterfaherne at gmail.com> escreveu:
>>>>> Hi, I am trying to draw circles based on some GPS points that I have
>>>>> uploaded. Creating a new .shp as a polygon will only create a shape
>>>>> based
>>>>> on the number of points. How can I draw a circle based on these
>>>>> points?
>>>>> It is very easy in ArcGIS but I can't find how to do it in Qgis.
>>>>> Please
>>>>> help?
>>>>> Thanks, Pete.
>>>>> _______________________________________________
>>>>> Qgis-user mailing list
>>>>> Qgis-user at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
