[Qgis-user] QGIS 2.8 runtime error
Leo Kris Palao
lk.palao at gmail.com
Tue Apr 7 18:51:39 PDT 2015
HI Ross and QGIS Users,
I tried the solution from the forum but still I am receiving runtime error.
I run process explorer and found that msvcr71.dll and msvcr100.dll in my
C:\OSGeo4W/bin\ directory. I tried to 1) remove both; 2) remove
msvcr71.dll, and 3) msvcr100.dll but still I am getting the runtime error
prompt when opening QGIS.
When I installed QGIS 2.8 I erased first all the qgis files in my C:\
directory before running the OSGeo installer. I do not know if this has
something to do with this issue. Because before I installed QGIS 2.6,
installed also using OSGeo installer, but I have no issue like this.
Thanks,
-Leo
On Tue, Mar 31, 2015 at 3:56 PM, McDonaldR <McDonaldR at angus.gov.uk> wrote:
> Hi Leo
> I had the same error a while back and I posted this to the UK QGIS user
> group:
> Anyone getting the following error on the latest update to QGIS via
> OSGeo4W? The problem is a copy of msvcr90.dll in the
> C:\OSGeo4W\apps\qgis\bin folder which clashes with the copy in
> C:\Windows\winsxs\ folder. Removing the DLL from the QGIS folder allows
> the program to start without a hitch. If you have QGIS DEV installed there
> is no issue.
> This post provided the answer and method:
> http://stackoverflow.com/questions/14552348/runtime-error-r6034-in-embedded-python-application/14680947#14680947
> This happened after using the OSGeo4W installer to upgrade to QGIS 2.6.1-2
> Whether this is just my install environment or affects everyone, I don’t
> know.
> Hope it helps
> Ross
> *From:* qgis-user-bounces at lists.osgeo.org [mailto:
> qgis-user-bounces at lists.osgeo.org] *On Behalf Of *Leo Kris Palao
> *Sent:* 31 March 2015 03:05
> *To:* QGIS Mailing List
> *Subject:* [Qgis-user] QGIS 2.8 runtime error
> Hi QGIS Users,
> I have this problem when opening QGIS. It reports:
> Runtime error:
> Program C:\OSGeo4W\bin\qgis-bin.exe
> R6034
> An application has made an attempt to load C runtime library incorrectly.
> Please contact the application's support team for more information.
> After clicking "OK" it loads QGIS. I have not tried to process anything so
> I have no idea if this will affect some of the functions in QGIS.
> I am using Windows 7 64 bit. Installed QGIS via OSGeo 32bit.
> note: I already restarted my laptop.
> Thanks in advance for any help,
> -Leo
> This message is strictly confidential. If you have received this in error,
> please inform the sender and remove it from your system. If received in
> error you may not copy, print, forward or use it or any attachment in any
> way. This message is not capable of creating a legal contract or a binding
> representation and does not represent the views of Angus Council. Emails
> may be monitored for security and network management reasons. Messages
> containing inappropriate content may be intercepted. Angus Council does not
> accept any liability for any harm that may be caused to the recipient
> system or data on it by this message or any attachment.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150408/765f644a/attachment.html>
