[Qgis-user] Issue building QGIS 64bit on windows platform
Paul Gathogo
pgathogo at gmail.com
Tue Apr 7 21:23:59 PDT 2015
Guys,
Am building QGIS 64bit on windows using the instructions provided here
https://github.com/qgis/QGIS/blob/master/INSTALL, but am getting a couple
of errors.
My development environment:
- Lenovo Thinkpad L540 - 12GB RAM
- Windows 7 Ultimate SP1 - 64bit
- Visual Studio Express 2010
- MS SDK 7 - 64bit
- Python2.7 - 64bit
- CMake 3.0.2
- Cygwin64
- OSGeo4W64
- QGIS 2.9.0 # this what I got when I did CMake (configure/generate)
Errors am getting when the build is done in VC++:
313>Time Elapsed 00:00:00.90
314>------ Skipped Build: Project: PACKAGE, Configuration: Release x64
314>Project not selected to build for this solution configuration
315>------ Skipped Build: Project: INSTALL, Configuration: Release x64
315>Project not selected to build for this solution configuration
========== Build: 223 succeeded, 2 failed, 0 up-to-date, 89 skipped
from VC++ output window I see the following nasty ones
12>InitializeBuildStatus:
12> Creating
"x64\Release\MetaSearch-62-stageinstall\MetaSearch-62-stageinstall.unsuccessfulbuild"
because "AlwaysCreate" was specified.
7>qextserialenumerator.obj : error LNK2019: unresolved external symbol
__imp_SetupDiGetDeviceRegistryPropertyA referenced in function "private:
static class QString __cdecl QextSerialEnumerator::getDeviceProperty(void
*,struct _SP_DEVINFO_DATA *,unsigned long)"
(?getDeviceProperty at QextSerialEnumerator@CA?AVQString
@PEAXPEAU_SP_DEVINFO_DATA at K@Z)
__imp_SetupDiOpenDevRegKey referenced in function "private: static bool
__cdecl QextSerialEnumerator::getDeviceDetailsWin(struct QextPortInfo
*,void *,struct _SP_DEVINFO_DATA *,unsigned __int64)"
(?getDeviceDetailsWin at QextSerialEnumerator@CA_NPEAUQextPortInfo@
PEAXPEAU_SP_DEVINFO_DATA at _K@Z)
__imp_SetupDiDestroyDeviceInfoList referenced in function "private: bool
__cdecl QextSerialEnumerator::matchAndDispatchChangedDevice(class QString
const &,struct _GUID const &,unsigned __int64)"
(?matchAndDispatchChangedDevice at QextSerialEnumerator@AEAA_NAEBVQString
@AEBU_GUID at _K@Z)
__imp_SetupDiGetDeviceInstanceIdA referenced in function "private: bool
(?matchAndDispatchChangedDevice at QextSerialEnumerator@AEAA_NAEBVQString@
AEBU_GUID at _K@Z)
__imp_SetupDiEnumDeviceInfo referenced in function "private: bool __cdecl
QextSerialEnumerator::matchAndDispatchChangedDevice(class QString const
@AEBU_GUID at _K@Z)
__imp_SetupDiGetClassDevsA referenced in function "private: bool __cdecl
AEBU_GUID at _K@Z)
7>spatialite.lib(gg_xml.obj) : error LNK2019: unresolved external symbol
xmlFreeDoc referenced in function splite_free_xml_schema_cache_item
7>spatialite.lib(virtualxpath.obj) : error LNK2001: unresolved external
symbol xmlFreeDoc
xmlSchemaFree referenced in function splite_free_xml_schema_cache_item
xmlSchemaFreeParserCtxt referenced in function
xmlDocGetRootElement referenced in function sniff_payload
symbol xmlDocGetRootElement
crc32 referenced in function gaiaXmlToBlob
7>spatialite.lib(gg_relations.obj) : error LNK2001: unresolved external
symbol crc32
compress referenced in function gaiaXmlToBlob
compressBound referenced in function gaiaXmlToBlob
xmlSchemaFreeValidCtxt referenced in function gaiaXmlToBlob
xmlSchemaValidateDoc referenced in function gaiaXmlToBlob
xmlSchemaNewValidCtxt referenced in function gaiaXmlToBlob
xmlReadMemory referenced in function gaiaXmlToBlob
symbol xmlReadMemory
xmlSchemaParse referenced in function gaiaXmlToBlob
xmlSchemaNewDocParserCtxt referenced in function gaiaXmlToBlob
xmlReadFile referenced in function gaiaXmlToBlob
xmlSetGenericErrorFunc referenced in function gaiaXmlToBlob
symbol xmlSetGenericErrorFunc
uncompress referenced in function gaiaXmlTextFromBlob
xmlDocDumpFormatMemory referenced in function gaiaXmlLoad
xmlXPathFreeObject referenced in function gaiaXmlGetInternalSchemaURI
symbol xmlXPathFreeObject
xmlXPathFreeContext referenced in function gaiaXmlGetInternalSchemaURI
symbol xmlXPathFreeContext
xmlFreeNode referenced in function setIsoId
xmlReplaceNode referenced in function setIsoId
xmlAddChild referenced in function setIsoId
xmlNewText referenced in function setIsoId
xmlNewNode referenced in function setIsoId
__imp_xmlFree referenced in function gaiaXmlBlobSetFileId
xmlSetNs referenced in function addIsoId
xmlNewNs referenced in function addIsoId
xmlAddNextSibling referenced in function addIsoId
xmlAddPrevSibling referenced in function addIsoId
xmlSearchNs referenced in function addIsoId
xmlSearchNsByHref referenced in function addIsoId
7>spatialite.lib(virtualxpath.obj) : error LNK2019: unresolved external
symbol xmlXPathFreeCompExpr referenced in function
gaiaIsValidXPathExpression
symbol xmlXPathCompile referenced in function gaiaIsValidXPathExpression
symbol xmlXPathEvalExpression referenced in function vxpath_eval_expr
symbol xmlXPathRegisterNs referenced in function vxpath_eval_expr
symbol xmlXPathNewContext referenced in function vxpath_eval_expr
7>spatialite.lib(virtualXL.obj) : error LNK2019: unresolved external symbol
freexl_get_cell_value referenced in function vXL_create
freexl_worksheet_dimensions referenced in function vXL_create
freexl_select_active_worksheet referenced in function vXL_create
freexl_get_info referenced in function vXL_create
freexl_close referenced in function vXL_create
freexl_open referenced in function vXL_create
7>spatialite.lib(gg_utf8.obj) : error LNK2019: unresolved external symbol
locale_charset referenced in function gaiaGetLocaleCharset
__imp_libiconv_close referenced in function gaiaConvertCharset
7>spatialite.lib(gg_shape.obj) : error LNK2001: unresolved external symbol
__imp_libiconv referenced in function gaiaConvertCharset
__imp_libiconv
__imp_libiconv_open referenced in function gaiaConvertCharset
__imp_libiconv_open
*7>D:\home\qgis_app\QGIS\build64\output\bin\Release\qgis_core.dll : fatal
error LNK1120: 52 unresolved externals*
*81>C:\Program Files
(x86)\MSBuild\Microsoft.Cpp\v4.0\Microsoft.CppCommon.targets(151,5): error
MSB6006: "cmd.exe" exited with code -1073741515.*
81>
81>Build FAILED.
81>
81>Time Elapsed 00:00:00.30
Any ideas what I might be missing?
regards
pgathogo
*Society is produced by our wants, and government by our wickedness*
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150408/79eb258a/attachment.html>
