[Qgis-user] making mistakes with raster calculator
    Nicolas Cadieux
    nicolas.cadieux at archeotec.ca
    Wed Apr  8 15:57:09 PDT 2015
The result of you operation will give you a raster with 0 (does not correspond ) and 1 (does correspond).  Then you need to multiply result that by 5. You can do it in one shot such as (raster < 2)*5.  If you do (raster <2)*raster, the results (1) will be multiplied by the original values of the raster. All other value will be multiplied by 0.
Nicolas Cadieux M.Sc.
Les Entreprises Archéotec inc.
8548, rue Saint-Denis Montréal H2P 2H2
Téléphone: 514.381.5112  Fax: 514.381.4995
www.archeotec.ca
Le 2015-04-08 18:30, "Giacomo Fontanelli-2 [via OSGeo.org]	" <ml-node+s1560n5200510h71 at n6.nabble.com> a écrit :
	Dear forum I use QGIS 2.8.1. I have a raster map, Float32, pixel values range from -0.7 to 1. I Would like to make a map with pixel having only two values: pixels with values <= 0 should be 0 pixels with values > 0 should be 5. the sintax ( "3_NDFI@1" <= 0 ) =0 AND  ( "3_NDFI@1" > 0 ) =5 doesn't work because it produces a map with only 0 values. In order to reach my goal I must do ( "3_NDFI@1" <= 0 ) =0 AND  ( "3_NDFI@1" > 0 ) =1 then multiply result by 5. What's the problem?  Is it possible to fulfil the purpose with only one raster operation? Thank you very much
Qgis-user mailing list
[hidden email]
http://lists.osgeo.org/mailman/listinfo/qgis-user
		If you reply to this email, your message will be added to the discussion below:
		http://osgeo-org.1560.x6.nabble.com/making-mistakes-with-raster-calculator-tp5200510.html
		To start a new topic under Quantum GIS - User, email ml-node+s1560n4125267h38@n6.nabble.com
		To unsubscribe from Quantum GIS - User, click here .
		NAML
View this message in context: http://osgeo-org.1560.x6.nabble.com/making-mistakes-with-raster-calculator-tp5200510p5200514.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150408/02f66195/attachment.html>
