[Qgis-user] making mistakes with raster calculator
Claas Leiner
claas.leiner at eschenlaub.de
Thu Apr 9 01:42:05 PDT 2015
Vou can do it with:
(( "3_NDFI at 1" <= 0 ) * 0) + (("3_NDFI at 1" > 0)*5)
Claas
Am 09.04.2015 um 00:09 schrieb Giacomo Fontanelli:
> Dear forum
> I use QGIS 2.8.1.
> I have a raster map, Float32, pixel values range from -0.7 to 1.
> I Would like to make a map with pixel having only two values:
> pixels with values <= 0 should be 0
> pixels with values > 0 should be 5.
> the sintax
> ( "3_NDFI at 1" <= 0 ) =0 AND ( "3_NDFI at 1" > 0 ) =5
> doesn't work because it produces a map with only 0 values.
> In order to reach my goal I must do
> ( "3_NDFI at 1" <= 0 ) =0 AND ( "3_NDFI at 1" > 0 ) =1
> then multiply result by 5.
> What's the problem?
> Is it possible to fulfil the purpose with only one raster operation?
> Thank you very much
