[Qgis-user] Converting TTF font to SVG
Lester Anderson
arctica1963 at gmail.com
Wed Apr 15 03:33:10 PDT 2015
Thanks for the info Richard, that makes it easier to sort out!
Cheers
Lester
On 15 April 2015 at 11:23, Richard McDonnell <richard.mcdonnell at opw.ie>
wrote:
> Lester,
> If the font is installed on your computer, QGIS should be able to use it
> in your symbol.
> Under Layer Property's, Style, select Font Marker in Symbol Layer Type.
> An alternative is to download and install Inkscape. It will allow you to
> insert the text you are looking for and save it as a SVG symbol.
> Regards,
> Richard McDonnell
> On 15/04/2015 10:55, Lester Anderson wrote:
> Hello,
> I would like to convert a TTF font to SVG for use in QGIS but all
> converters I have tried online fail to generate a result that is usable in
> QGIS. I made sure to set the path to my SVG folder correctly.
> No preview of the SVG is displayed when in the SVG marker option, so I am
> guessing that the converted file is not correct.
> Any ideas how to add new SVG? I am trying to get the USGS geology markers
> converted from a TTF.
> Cheers
> Lester
> Qgis-user mailing listQgis-user at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/qgis-user
> OPW - Ag féachaint don am atá le teacht - Ag caomhnú ón am atá thart
> OPW - Looking to the future - Caring for the past
> Email Disclaimer: http://www.opw.ie/en/disclaimer/
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150415/aaf52408/attachment.html>
