[Qgis-user] use a grass extension via Qgis interface?
    Radim Blazek
    radim.blazek at gmail.com
    Wed Apr 15 06:51:09 PDT 2015
On Wed, Apr 15, 2015 at 3:29 PM, Carlos Cerdán <sig.upagu at gmail.com> wrote:
> Hi Image93?
> Not all GRASS modules have graphical interface into QGIS, but ALL of them
> can work in QGIS through the shell prompt, so if you have GRASS 7.0 working
> through QGIS, then you can call all their modules via the shell.
If you mean the shell in the GRASS Plugin, then no, it is not yet
possible, because the plugin is not yet upgraded to GRASS 7. That is
subject of  ongoing GRASS plugin upgrade[1]. The upgrade should also
introduce generic UI for modules without UI defined for the plugin
(without .qgm).
[1] http://www.gissula.eu/qgis-grass-plugin-crowdfunding/
Radim
> Good luck
> Carlos Cerdan
> 2015-04-15 8:06 GMT-05:00 image93 <lcelati at cci-paris-idf.fr>:
>> Good afternoon,
>> I'm a qgis and grass user. Currently i'm working on isochrone maps on
>> Grass
>> 7.0 thanks to v.isochrones Grass 7.0 extension.
>> Is there a  way in order to use this v.isochrones extension via Qgis
>> interface?
>> Thanks.
>> View this message in context:
>> http://osgeo-org.1560.x6.nabble.com/use-a-grass-extension-via-Qgis-interface-tp5201448.html
>> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
