[Qgis-user] use a grass extension via Qgis interface?
Carlos Cerdán
sig.upagu at gmail.com
Wed Apr 15 09:33:51 PDT 2015
Thank you Radim
Yes, I wanted to say the shell in the GRASS plugin. It sounds that the
next incoming upgrade will be useful for take advantage of all the GRASS
modules. It's great!!
Best wishes
Carlos
2015-04-15 8:51 GMT-05:00 Radim Blazek <radim.blazek at gmail.com>:
> On Wed, Apr 15, 2015 at 3:29 PM, Carlos Cerdán <sig.upagu at gmail.com>
> wrote:
> > Hi Image93?
> > Not all GRASS modules have graphical interface into QGIS, but ALL of them
> > can work in QGIS through the shell prompt, so if you have GRASS 7.0
> working
> > through QGIS, then you can call all their modules via the shell.
> If you mean the shell in the GRASS Plugin, then no, it is not yet
> possible, because the plugin is not yet upgraded to GRASS 7. That is
> subject of ongoing GRASS plugin upgrade[1]. The upgrade should also
> introduce generic UI for modules without UI defined for the plugin
> (without .qgm).
> [1] http://www.gissula.eu/qgis-grass-plugin-crowdfunding/
> Radim
> > Good luck
> > Carlos Cerdan
> > 2015-04-15 8:06 GMT-05:00 image93 <lcelati at cci-paris-idf.fr>:
> >> Good afternoon,
> >> I'm a qgis and grass user. Currently i'm working on isochrone maps on
> >> Grass
> >> 7.0 thanks to v.isochrones Grass 7.0 extension.
> >> Is there a way in order to use this v.isochrones extension via Qgis
> >> interface?
> >> Thanks.
> >> View this message in context:
> http://osgeo-org.1560.x6.nabble.com/use-a-grass-extension-via-Qgis-interface-tp5201448.html
> >> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> >> _______________________________________________
> >> Qgis-user mailing list
> >> Qgis-user at lists.osgeo.org
> >> http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150415/1b157efd/attachment.html>
