[Qgis-user] QGIS and Oracle Mastermap Vector indexing
Dixon, Stephen Stephen.Dixon at dumgal.gov.uk
Fri Apr 17 02:32:04 PDT 2015
I'm having problems when using MasterMap vector data for snapping in QGIS. This data is being brought into QGIS from an oracle database.
It works fine until I go onto another layer (Not MasterMap Vector layers)  and try to add a feature. It appears to try and index the whole of the MasterMap vector database, which causes QGIS to fall over.
Is they a way to restrict the indexing to only index the area that is currently rendered or a workaround maybe to allow me to snap to the vector data without having to take a separate extract of the area required each time?
Cheers
Stephen
Any email message sent or received by the
Council may require to be disclosed by the
Council under the provisions of the Freedom
of Information (Scotland) Act 2002.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150417/b9367a94/attachment.html>
