[Qgis-user] Dotted line symbol in QGIS
    David Fawcett
    david.fawcett at gmail.com
    Fri Apr 17 09:01:08 PDT 2015
Here is another solution that would work if you are not mapping live data,
and you can use a derived product.  Convert your polygon dataset to lines.
The, use Vector>Dissolve to remove duplicated lines where they are
overlapping.
David.
On Fri, Apr 17, 2015 at 9:54 AM, Basques, Bob (CI-StPaul) <
bob.basques at ci.stpaul.mn.us> wrote:
>  Hey Stefan,
> Neat trick/idea with the white line.  I’ll have to write that one down.
> Hmm, I wonder instead of white though, if you could convert that to
> transparent as well . . . .
> Bobb
> *From:* qgis-user-bounces at lists.osgeo.org [mailto:
> qgis-user-bounces at lists.osgeo.org] *On Behalf Of *Ziegler Stefan
> *Sent:* Friday, April 17, 2015 7:05 AM
> *To:* 'Chris Buckmaster'; 'qgis-user at lists.osgeo.org'
> *Subject:* Re: [Qgis-user] Dotted line symbol in QGIS
> Hi
> Put a white line under the dotted line („Add symbol layer“).
> Perhaps there is also a solution with the blending modes?
> Regards
> Stefan
> *Von:* qgis-user-bounces at lists.osgeo.org [
> mailto:qgis-user-bounces at lists.osgeo.org
> <qgis-user-bounces at lists.osgeo.org>] *Im Auftrag von *Chris Buckmaster
> *Gesendet:* Freitag, 17. April 2015 13:40
> *An:* qgis-user at lists.osgeo.org
> *Betreff:* [Qgis-user] Dotted line symbol in QGIS
> Hi
> I have a boundary layer that I want to symbolise with a dotted line. The
> outer boundary appears ok, but where two polygons are adjacent to each
> other, the dotted line becomes virtually solid (indicated below). How can I
> make these lines appear the same as my outer boundary lines…
>  Thanks, Chris
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150417/ff17ddee/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150417/ff17ddee/attachment.png>
