[Qgis-user] Dotted line symbol in QGIS
Chris Buckmaster
chris.buckmaster at runnymede.gov.uk
Fri Apr 17 09:08:15 PDT 2015
Thanks David although we are using live data. Stefan’s approach is a good one so I think I will continue with that, thanks for everyone’s responses
Chris
From: David Fawcett [mailto:david.fawcett at gmail.com]
Sent: 17 April 2015 17:01
To: Basques, Bob (CI-StPaul)
Cc: Ziegler Stefan; Chris Buckmaster; qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] Dotted line symbol in QGIS
Here is another solution that would work if you are not mapping live data, and you can use a derived product. Convert your polygon dataset to lines. The, use Vector>Dissolve to remove duplicated lines where they are overlapping.
David.
On Fri, Apr 17, 2015 at 9:54 AM, Basques, Bob (CI-StPaul) <bob.basques at ci.stpaul.mn.us<mailto:bob.basques at ci.stpaul.mn.us>> wrote:
Hey Stefan,
Neat trick/idea with the white line. I’ll have to write that one down. Hmm, I wonder instead of white though, if you could convert that to transparent as well . . . .
Bobb
From: qgis-user-bounces at lists.osgeo.org<mailto:qgis-user-bounces at lists.osgeo.org> [mailto:qgis-user-bounces at lists.osgeo.org<mailto:qgis-user-bounces at lists.osgeo.org>] On Behalf Of Ziegler Stefan
Sent: Friday, April 17, 2015 7:05 AM
To: 'Chris Buckmaster'; 'qgis-user at lists.osgeo.org<mailto:qgis-user at lists.osgeo.org>'
Hi
Put a white line under the dotted line („Add symbol layer“).
Perhaps there is also a solution with the blending modes?
Regards
Stefan
Von: qgis-user-bounces at lists.osgeo.org<mailto:qgis-user-bounces at lists.osgeo.org> [mailto:qgis-user-bounces at lists.osgeo.org] Im Auftrag von Chris Buckmaster
Gesendet: Freitag, 17. April 2015 13:40
An: qgis-user at lists.osgeo.org<mailto:qgis-user at lists.osgeo.org>
Betreff: [Qgis-user] Dotted line symbol in QGIS
Hi
I have a boundary layer that I want to symbolise with a dotted line. The outer boundary appears ok, but where two polygons are adjacent to each other, the dotted line becomes virtually solid (indicated below). How can I make these lines appear the same as my outer boundary lines…
[cid:image001.png at 01D07931.17B10560]
Thanks, Chris
Qgis-user mailing list
Qgis-user at lists.osgeo.org<mailto:Qgis-user at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150417/e6070255/attachment.html>
Type: image/png
Desc: image001.png
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150417/e6070255/attachment.png>
