[Qgis-user] Composite satellite images
    RNanclares
    raulnanclares at gmail.com
    Fri Apr 17 09:26:53 PDT 2015
Hi Susan,
first you need to use the merge/combine (i don't remember the exact name of
the tool in English) located in the Raster > Miscellaneous menu. You have to
check the option 'stack layers'.
To pansharpen the image, first you have to see if you have Orfeo Toolbox
installed and configured (in the Processing menu). If it is installed you
can continue by using the sumperimpose tool (in the processing toolbox).
After the superimpose has finished you can do the pansharpening using the
pansharpening (rcs) algorithm found in the processing toolbox.
Cheers
View this message in context: http://osgeo-org.1560.x6.nabble.com/Composite-satellite-images-tp5201852p5201867.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
