[Qgis-user] Re : Dotted line symbol in QGIS
Junior
delazj at gmail.com
Fri Apr 17 11:39:14 PDT 2015
Hi.
and what about using the "Draw line only inside polygon" option?
Envoyé depuis mon HTC
----- Reply message -----
De : "Chris Buckmaster" <chris.buckmaster at runnymede.gov.uk>
Pour : "David Fawcett" <david.fawcett at gmail.com>, "Basques, Bob (CI-StPaul)" <bob.basques at ci.stpaul.mn.us>
Cc : "qgis-user at lists.osgeo.org" <qgis-user at lists.osgeo.org>
Objet : [Qgis-user] Dotted line symbol in QGIS
Date : ven., avr. 17, 2015 18:08
Thanks David although we are using live data. Stefan’s approach is a good one so I think I will continue with that, thanks for everyone’s responses
Chris
From: David Fawcett [mailto:david.fawcett at gmail.com]
Sent: 17 April 2015 17:01
To: Basques, Bob (CI-StPaul)
Cc: Ziegler Stefan; Chris Buckmaster; qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] Dotted line symbol in QGIS
Here is another solution that would work if you are not mapping live data, and you can use a derived product. Convert your polygon dataset to lines. The, use Vector>Dissolve to remove duplicated lines where
they are overlapping.
David.
On Fri, Apr 17, 2015 at 9:54 AM, Basques, Bob (CI-StPaul) <bob.basques at ci.stpaul.mn.us> wrote:
Hey Stefan,
Neat trick/idea with the white line. I’ll have to write that one down. Hmm, I wonder instead of white though,
if you could convert that to transparent as well . . . .
Bobb
qgis-user-bounces at lists.osgeo.org [mailto:qgis-user-bounces at lists.osgeo.org]
On Behalf Of Ziegler Stefan
Sent: Friday, April 17, 2015 7:05 AM
To: 'Chris Buckmaster'; 'qgis-user at lists.osgeo.org'
Hi
Put a white line under the dotted line („Add symbol layer“).
Perhaps there is also a solution with the blending modes?
Regards
Stefan
Von:
Im Auftrag von Chris Buckmaster
Gesendet: Freitag, 17. April 2015 13:40
An: qgis-user at lists.osgeo.org
Betreff: [Qgis-user] Dotted line symbol in QGIS
Hi
I have a boundary layer that I want to symbolise with a dotted line. The outer boundary appears ok, but where two polygons are adjacent to each other, the dotted line becomes virtually solid (indicated below). How can I make these lines appear the same as my
outer boundary lines…
Thanks, Chris
Qgis-user mailing list
Qgis-user at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150417/f9b22f19/attachment.html>
