[Qgis-user] Re :  Dotted line symbol in QGIS
    Andreas Neumann
    a.neumann at carto.net
    Sat Apr 18 01:42:33 PDT 2015
The stroke only on inside option would be useful - but for dashed/dotted
lines you would still get undesirable results because of shifted dashes,
due to different line-length of the polygon borders.
So the only two options I see is Stephans solution - which works fine as
long as your map background is white anyway, or to make sure that the
double lines are eliminated, achievable with a  number of tools (but not
very dynamic, esp. for large data that changes a lot).
Or, the third option would be to use a topological data set from the
start (e.g. GRASS data a topological Postgis tables).
Andreas
On 17.04.2015 20:39, Junior wrote:
> Hi.
> and what about using the "Draw line only inside polygon" option?
> Envoyé depuis mon HTC
> ----- Reply message -----
> De : "Chris Buckmaster" <chris.buckmaster at runnymede.gov.uk>
> Pour : "David Fawcett" <david.fawcett at gmail.com>, "Basques, Bob
> (CI-StPaul)" <bob.basques at ci.stpaul.mn.us>
> Cc : "qgis-user at lists.osgeo.org" <qgis-user at lists.osgeo.org>
> Objet : [Qgis-user] Dotted line symbol in QGIS
> Date : ven., avr. 17, 2015 18:08
> Thanks David although we are using live data. Stefan’s approach is a
> good one so I think I will continue with that, thanks for everyone’s
> responses
> Chris
> *From:*David Fawcett [mailto:david.fawcett at gmail.com]
> *Sent:* 17 April 2015 17:01
> *To:* Basques, Bob (CI-StPaul)
> *Cc:* Ziegler Stefan; Chris Buckmaster; qgis-user at lists.osgeo.org
> *Subject:* Re: [Qgis-user] Dotted line symbol in QGIS
> Here is another solution that would work if you are not mapping live
> data, and you can use a derived product.  Convert your polygon dataset
> to lines.  The, use Vector>Dissolve to remove duplicated lines where
> they are overlapping.
> David.
> On Fri, Apr 17, 2015 at 9:54 AM, Basques, Bob (CI-StPaul)
> <bob.basques at ci.stpaul.mn.us <mailto:bob.basques at ci.stpaul.mn.us>> wrote:
> Hey Stefan,
> Neat trick/idea with the white line.  I’ll have to write that one
> down.  Hmm, I wonder instead of white though, if you could convert
> that to transparent as well . . . .
> Bobb
> *From:*qgis-user-bounces at lists.osgeo.org
> <mailto:qgis-user-bounces at lists.osgeo.org>
> [mailto:qgis-user-bounces at lists.osgeo.org
> <mailto:qgis-user-bounces at lists.osgeo.org>] *On Behalf Of *Ziegler Stefan
> *Sent:* Friday, April 17, 2015 7:05 AM
> *To:* 'Chris Buckmaster'; 'qgis-user at lists.osgeo.org
> <mailto:qgis-user at lists.osgeo.org>'
> Hi
> Put a white line under the dotted line („Add symbol layer“).
> Perhaps there is also a solution with the blending modes?
> Regards
> Stefan
> *Von:*qgis-user-bounces at lists.osgeo.org
> [mailto:qgis-user-bounces at lists.osgeo.org] *Im Auftrag von *Chris
> Buckmaster
> *Gesendet:* Freitag, 17. April 2015 13:40
> *An:* qgis-user at lists.osgeo.org <mailto:qgis-user at lists.osgeo.org>
> *Betreff:* [Qgis-user] Dotted line symbol in QGIS
> Hi
> I have a boundary layer that I want to symbolise with a dotted line.
> The outer boundary appears ok, but where two polygons are adjacent to
> each other, the dotted line becomes virtually solid (indicated below).
> How can I make these lines appear the same as my outer boundary lines…
> Thanks, Chris
> Qgis-user mailing list
> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150418/f46362b5/attachment.html>
