[Qgis-user] delete overlapped polygons
Giacomo Fontanelli
giacomofontanelli76 at gmail.com
Mon Apr 20 02:30:43 PDT 2015
Dear Randy
unfortunately the dimensions of the smaller polygons are very variable and
it's hard to apply your method.
I'm gonna try with GRASS or OTB or SAGA.
I will keep you in touch.
Thank you very much
Giacomo
On Sun, Apr 19, 2015 at 6:54 PM, Randal Hale <
rjhale at northrivergeographic.com> wrote:
> I believe you can do it this way (as I'm experimenting with this very
> thing). Of course - if you have very small polygons with even smaller
> polygons this wouldn't work.
> Select features using an expression and let your expression be $area <
> square units you are looking for.
> I wanted to select everything in my layer less than 10 acres (I am working
> in Feet) so I entered $area < 435600 and have quite a few polygons selected
> now. I am checking to make sure it has done what I wanted.
> Hope this helps - I'm pretty sure there is a more elegant solution than
> $area - but so far this works for me.
> Randy
> On 04/19/2015 12:38 PM, Giacomo Fontanelli wrote:
> Hello forum
> this post is similar to my last one, but not totally the same.
> Thank you for making me know the Sieve filter.
> I have a vector layer.
> I have some polygons that apparently seem to be lying on bigger polygons
> and totally included on this, but if you delete the small ones they produce
> holes on the big polygons with the same dimension and shape of the small
> polygons.
> Well: this is the result I'd like to obtain, I mean I would like to
> automatically delete the smaller polygons producing the described holes.
> How can I do this?
> Thank you very much
> Qgis-user mailing listQgis-user at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/qgis-user
> Randal Hale
> North River Geographic Systems, Inchttp://www.northrivergeographic.com423.653.3611 rjhale at northrivergeographic.com
> twitter:rjhale http://about.me/rjhalehttp://www.northrivergeographic.com/introduction-to-quantum-gis
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150420/ef91b52b/attachment.html>
