[Qgis-user] trigonometric angle in aspect maps
Even Rouault even.rouault at spatialys.com
Wed Apr 22 04:07:08 PDT 2015
Le mercredi 22 avril 2015 12:59:53, Larissa Junek a écrit :
> Hello,
> I look for a GIS expert who can give a good description of the
> trigonometric angle that can be produced when using the GDAL aspect
> algorithm in Processing.
> I need this description for the user manual 2.8..
Larissa,
from the GDAL manual: http://gdal.org/gdaldem.html
 aspect
This command outputs a 32-bit float raster with values between 0° and 360°
representing the azimuth that slopes are facing. The definition of the azimuth
is such that : 0° means that the slope is facing the North, 90° it's facing
the East, 180° it's facing the South and 270° it's facing the West (provided
that the top of your input raster is north oriented). The aspect value -9999
is used as the nodata value to indicate undefined aspect in flat areas with
slope=0.
The following specifics options are available :
-trigonometric:
    return trigonometric angle instead of azimuth. Thus 0° means East, 90°
North, 180° West, 270° South
-zero_for_flat:
    return 0 for flat areas with slope=0, instead of -9999
By using those 2 options, the aspect returned by gdaldem aspect should be
identical to the one of GRASS r.slope.aspect. Otherwise, it's identical to the
one of Matthew Perry's aspect.cpp utility.
Even
http://www.spatialys.com
