[Qgis-user] GDAL Fill nodata Algorithm
Nicolas Cadieux
nicolas.cadieux at archeotec.ca
Wed Apr 22 12:00:03 PDT 2015
I believe so but I usually use the .tiff format. Just make sure the "null data" value is specified in the raster. You can do that under the "save as". Specifying additional null value in the layer properties does not work.
Nicolas Cadieux M.Sc.
Les Entreprises Archéotec inc.
8548, rue Saint-Denis Montréal H2P 2H2
Téléphone: 514.381.5112 Fax: 514.381.4995
www.archeotec.ca
On Apr 22, 2015 9:50 AM, "Larissa Junek [via OSGeo.org]" <ml-node+s1560n5202470h31 at n6.nabble.com> wrote:
Hello,
does someone know if you can use any GDAL-supported raster layer with
the Processing Fill nodata Algorithm?
Kinde regards,
Larissa
Qgis-user mailing list
[hidden email]
http://lists.osgeo.org/mailman/listinfo/qgis-user
If you reply to this email, your message will be added to the discussion below:
http://osgeo-org.1560.x6.nabble.com/GDAL-Fill-nodata-Algorithm-tp5202470.html
To start a new topic under Quantum GIS - User, email ml-node+s1560n4125267h38@n6.nabble.com
To unsubscribe from Quantum GIS - User, click here .
NAML
View this message in context: http://osgeo-org.1560.x6.nabble.com/GDAL-Fill-nodata-Algorithm-tp5202470p5202536.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150422/4f12ed57/attachment.html>
