[Qgis-user] GDAL Fill nodata Algorithm
Larissa Junek
junek at gbd-consult.de
Thu Apr 23 04:31:56 PDT 2015
Hello Nicolas,
I have further questions concerning the use of the algorithm!
Am Wed, 22 Apr 2015 12:00:03 -0700 (PDT)
schrieb Nicolas Cadieux <nicolas.cadieux at archeotec.ca>:
> Hi,
> I believe so but I usually use the .tiff format. Just
> make sure the "null data" value is specified in the raster. You can
> do that under the "save as". Specifying additional null
> value in the layer properties does not work.
Is it right that the no-data values must be represented by 0 so that
the interpolation works properly then?
Nicolas
> Cadieux M.Sc. Les Entreprises Archéotec inc. 8548, rue
> Saint-Denis Montréal H2P 2H2
> Téléphone: 514.381.5112 Fax: 514.381.4995
> www.archeotec.ca On Apr 22, 2015 9:50 AM, "Larissa Junek [via
> OSGeo.org]" <ml-node+s1560n5202470h31 at n6.nabble.com>
> wrote:
> Hello,
> does someone know if you can use any GDAL-supported raster layer with
> the Processing Fill nodata Algorithm?
> Kinde regards,
> Larissa
> Qgis-user mailing list
> [hidden email]
> If you reply to this email, your message will be
> added to the discussion below:
> http://osgeo-org.1560.x6.nabble.com/GDAL-Fill-nodata-Algorithm-tp5202470.html
> To start a new topic under Quantum GIS - User, email
> ml-node+s1560n4125267h38@n6.nabble.com To unsubscribe from
> Quantum GIS - User, click here . NAML
> http://osgeo-org.1560.x6.nabble.com/GDAL-Fill-nodata-Algorithm-tp5202470p5202536.html
> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
