[Qgis-user] Misaligned Prints
Nicolas Cadieux
nicolas.cadieux at archeotec.ca
Fri Apr 24 07:14:23 PDT 2015
Zoom on the screen and then use the "save as image". Then pan and re-use again. The jpg will have a world file. Load those In the project.
Nicolas Cadieux M.Sc.
Les Entreprises Archéotec inc.
8548, rue Saint-Denis Montréal H2P 2H2
Téléphone: 514.381.5112 Fax: 514.381.4995
www.archeotec.ca
On Apr 24, 2015 8:59 AM, "Simon Lange [via OSGeo.org]" <ml-node+s1560n5202830h91 at n6.nabble.com> wrote: Using 2.8. Wien.
Here again a well discussed problem with few solutions (which don´t work out for my issue): I use OpenLayer plugin for google physical maps as background, then overlay a shp. and try to print out after arranging everything in map composer. Looks good until the end, when in the pdf. the OSM is at a different place or seems to have a different scale. Somebody has got a solution?
Felix
Qgis-user mailing list
[hidden email]
http://lists.osgeo.org/mailman/listinfo/qgis-user
If you reply to this email, your message will be added to the discussion below:
http://osgeo-org.1560.x6.nabble.com/Misaligned-Prints-tp5202830.html
To start a new topic under Quantum GIS - User, email ml-node+s1560n4125267h38@n6.nabble.com
To unsubscribe from Quantum GIS - User, click here .
NAML
View this message in context: http://osgeo-org.1560.x6.nabble.com/Misaligned-Prints-tp5202830p5202851.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150424/b6e2a251/attachment.html>
