[Qgis-user] processing 'Import Vector into PostGIS database (available connections)'
Richard McDonnell
richard.mcdonnell at opw.ie
Wed Apr 29 07:47:43 PDT 2015
There is an addon for QGIS called split, which will easily export vector
data to a PostGIS database.
You mention having issues with authentication, just make sure the user
(database) has the correct access.
You can also create a new user in PgAdmin3, giving full access.
I hope this is of help.
Regards,
Richard.
On 29/04/2015 10:44, Larissa Junek wrote:
> Hello,
> is there someone with experience in using the processing GDAL 'Import
> Vector into PostGIS database (available connections)' algorithm?
> I have problems with the authentication to the PostGIS database and
> look for a workflow which can be inserted into the user manual then.
> Kind regards,
> Larissa
> Qgis-user mailing list
OPW - Ag féachaint don am atá le teacht - Ag caomhnú ón am atá thart
OPW - Looking to the future - Caring for the past
Email Disclaimer: http://www.opw.ie/en/disclaimer/
Type: text/x-vcard
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150429/ddbf7a87/attachment.vcf>
