[Qgis-user] Extract raster cell-value statistics (min, max, count, sum) within a polygone
Johan Nilsson
joni8135 at gmail.com
Wed Apr 29 14:24:12 PDT 2015
Ok. Thanks. Seems like g.region is from equator and greenwich, south 0 and
west 0.
2015-04-29 18:44 GMT+02:00 Micha Silver <micha at arava.co.il>:
> On 04/29/2015 03:15 PM, Johan Nilsson wrote:
> Have now tried to run v.rast.stats in Grass 7.0. It start and run 100%
> off one core in hours, until a file in ~/grassdata/location/PERMANENT/.tmp/
> inflate to the disk is full, approximate 150GB :(
> Whoa!
> Check the region settings before you try again:
> g.region -p
> This is FAQ #0 for all work with GRASS. The v.rast.stats module works by
> first rasterizing the vector polygons into a temporary raster. If you
> region is very large, and resolution setting is very small, you might be
> getting a huge temporary raster.
> Have made topology check on the vector-data and imported it to grassdb.
> Will see if I can collect usefull data and ask on grass-user list.
> Stupid Ubuntu 14.04 to not messure invisible files in the normal
> file-manager, had gone faster to pinpoint the problem.
> /Cheers
> 2015-04-19 18:54 GMT+02:00 Micha Silver <micha at arava.co.il>:
>> On 04/19/2015 12:34 PM, Johan Nilsson wrote:
>> Zonal statistics work well to extract, numers of cells(counts) , sum of
>> the value (sum) and also average (mean) But I want the minimum AND
>> max-value and also standard error, if possible. Is there another plugin or
>> a tutorial how it may bee done in another way.
>> The GRASS module v.rast.stats does what you want. But it's not in the
>> Processing toolbox. You can import your raster into a GRASS mapset then do
>> the analysis directly within GRASS.
>> The code to Zonal statistics are here, but I'm total lost in how it
>> work.
>> https://github.com/qgis/QGIS/blob/a2f51260db5357917e86b78f1bb2915379d670dd/src/analysis/vector/qgszonalstatistics.cpp
>> /Cheers
>> This mail was received via Mail-SeCure System.
>> Qgis-user mailing listQgis-user at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150429/fe40642b/attachment.html>
