[Qgis-user] Any working GRASS in QGIS available?
    Bernd Vogelgesang
    bernd.vogelgesang at gmx.de
    Sun Aug  2 03:32:28 PDT 2015
Hi Alex,
Am 02.08.2015, 01:22 Uhr, schrieb Alex Mandel <tech_dev at wildintellect.com>:
> It's not a Windows/Ubuntu/Mac/OS thing, it's a QGIS + GRASS version
> change thing.
> Please indicate which version of QGIS and GRASS you are trying to get
> working.
Actually I do not mind any more what version I would like to get working.
I would have preferred the 2.8-LTR branch with no-matter-what GRASS
version.
I just would like to be able to finish my project, and there is
unfortunately no alternative to the GRASS algos in my model.
> QGIS 2.6 and older works with GRASS 6, 2.8+ sometimes is built to work
> with GRASS 7 (though possibly also with GRASS 6).
Mhm, reverting to 2.6 ... Lets see if this still possible at all ...
> If you want a guaranteed working setup ASAP download a copy of OSGeo
> Live Virtual Machine, we made sure that it works in that.
> http://live.osgeo.org
Will give it a try. Download will take another 1.5 hours ...
So does that mean that even your do not have a working GRASS in a recent
QGIS by "normal" means but the osgeo VM?
> Thanks,
> Alex
Cheers
Bernd
> On 2015-08-01 14:41, Bernd Vogelgesang wrote:
>> Hi guys,
>> is it just bad karma, that I seem not to able to get a working GRASS in
>> QGIS? Or did I miss the big advertisement "GRASS out of order"
>> somewhere.
>> For nearly 2 weeks, I tried to get things to work in Ubuntu/Mint, and
>> tried every possible/impossible repository, but always GRASS has missing
>> dependencies, the forms open in Processing, but the algos don't run
>> through, or the functions are working in Processing, but failing in the
>> modeller.
>> As I really got to finish a model in the Modeller including some GRASS
>> algos, I finally turned on my VM with Windows ...
>> but what the heck? Same s...t there!
>> I really wonder why there aren't many post about trouble with GRASS on
>> this list or at stackexchange, normally this would explode when things
>> like these happen.
>> So am I really the one with the bad karma, do you all other simply not
>> use GRASS in processing as much as I do, or do you all simply have
>> working installs, so there is not problem?
>> Please, at least one: Do you have an install under Ubuntu or Windows,
>> where GRASS algos are functional in the Modeler ? If yes, which
>> version/what did you do?
>> ... Soon, I will go and find me a rope ...
>> Bernd
Bernd Vogelgesang
Siedlerstraße 2
91083 Baiersdorf/Igelsdorf
Tel: 09133-825374
