[Qgis-user] Any working GRASS in QGIS available?
Alex Mandel
tech_dev at wildintellect.com
Sat Aug 1 16:22:51 PDT 2015
It's not a Windows/Ubuntu/Mac/OS thing, it's a QGIS + GRASS version
change thing.
Please indicate which version of QGIS and GRASS you are trying to get
working.
QGIS 2.6 and older works with GRASS 6, 2.8+ sometimes is built to work
with GRASS 7 (though possibly also with GRASS 6).
If you want a guaranteed working setup ASAP download a copy of OSGeo
Live Virtual Machine, we made sure that it works in that.
http://live.osgeo.org
Thanks,
Alex
On 2015-08-01 14:41, Bernd Vogelgesang wrote:
> Hi guys,
> is it just bad karma, that I seem not to able to get a working GRASS in
> QGIS? Or did I miss the big advertisement "GRASS out of order" somewhere.
> For nearly 2 weeks, I tried to get things to work in Ubuntu/Mint, and
> tried every possible/impossible repository, but always GRASS has missing
> dependencies, the forms open in Processing, but the algos don't run
> through, or the functions are working in Processing, but failing in the
> modeller.
> As I really got to finish a model in the Modeller including some GRASS
> algos, I finally turned on my VM with Windows ...
> but what the heck? Same s...t there!
> I really wonder why there aren't many post about trouble with GRASS on
> this list or at stackexchange, normally this would explode when things
> like these happen.
> So am I really the one with the bad karma, do you all other simply not
> use GRASS in processing as much as I do, or do you all simply have
> working installs, so there is not problem?
> Please, at least one: Do you have an install under Ubuntu or Windows,
> where GRASS algos are functional in the Modeler ? If yes, which
> version/what did you do?
> ... Soon, I will go and find me a rope ...
> Bernd
