[Qgis-user] How to convert ECW using open source packages into something else?
Simon Cropper contact at simonchristophercropper.com
Mon Aug 3 21:04:12 PDT 2015
On 04/08/15 13:58, Andre Joost wrote:
> Am 04.08.2015 um 05:45 schrieb Simon Cropper:
>> My first question is, what is a good alternative to ECW files for use on
>> QGIS?
> Geotiff should always work on QGIS. BTW, write support for ECW is
> still limited without a license.
OK. GeoTiff sound good.
>> The second question, how do I convert the ECW file into this format
>> without using a propriety software package?
> Ubuntugis still holds ecw packages for GDAL 1.10 on raring, quantal,
> precise and lucid. So you can set up a virtual box inside your OS with
> one of those ubuntu versions, and install GDAL 1.10 with ECW support
> inside it to convert ecw files to Geotiff format. Data exchange
> between the virtual box and your host OS is possible with shared folders.
OK. Thanks.
> HTH,
> André Joost
> Qgis-user mailing list
Cheers Simon
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150804/0b0b5b97/attachment.html>
