[Qgis-user] How to convert ECW using open source packages into something else?
Andre Joost
andre+joost at nurfuerspam.de
Mon Aug 3 20:58:26 PDT 2015
Am 04.08.2015 um 05:45 schrieb Simon Cropper:
> My first question is, what is a good alternative to ECW files for use on
> QGIS?
Geotiff should always work on QGIS. BTW, write support for ECW is still
limited without a license.
> The second question, how do I convert the ECW file into this format
> without using a propriety software package?
Ubuntugis still holds ecw packages for GDAL 1.10 on raring, quantal,
precise and lucid. So you can set up a virtual box inside your OS with
one of those ubuntu versions, and install GDAL 1.10 with ECW support
inside it to convert ecw files to Geotiff format. Data exchange between
the virtual box and your host OS is possible with shared folders.
HTH,
André Joost
