[Qgis-user] Is qgis 2.10 support the last proj epsg db ?
    Jürgen E. Fischer
    jef at norbit.de
    Tue Aug  4 11:26:01 PDT 2015
Hi Andrea,
On Tue, 04. Aug 2015 at 20:20:17 +0200, Andrea Peri wrote:
> But from my first test with the qgis 2.8.x I can see that the qgis 2.8
> don't understand and do not show the new epsg codes in the list of
> available from wms service.
> I guess this happened because the qgis has an own internal db that is
> quite non update to the last epsg db.
> Is this situation update with the last qgis 2.10 ?
QGIS' internal database should be synced with the installed gdal on install
(via crssync).  So it doesn't depend on qgis itself, but the installed GDAL.
Jürgen
Jürgen E. Fischer           norBIT GmbH             Tel. +49-4931-918175-31
Dipl.-Inf. (FH)             Rheinstraße 13          Fax. +49-4931-918175-50
Software Engineer           D-26506 Norden             http://www.norbit.de
QGIS release manager (PSC)  Germany                    IRC: jef on FreeNode
Desc: Digital signature
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150804/77f33dd6/attachment.sig>
