[Qgis-user] Is qgis 2.10 support the last proj epsg db ?
Even Rouault
even.rouault at spatialys.com
Tue Aug 4 11:37:03 PDT 2015
On Tuesday 04 August 2015 20:26:01 Jürgen E. Fischer wrote:
> Hi Andrea,
> On Tue, 04. Aug 2015 at 20:20:17 +0200, Andrea Peri wrote:
> > But from my first test with the qgis 2.8.x I can see that the qgis 2.8
> > don't understand and do not show the new epsg codes in the list of
> > available from wms service.
> > I guess this happened because the qgis has an own internal db that is
> > quite non update to the last epsg db.
> > Is this situation update with the last qgis 2.10 ?
> QGIS' internal database should be synced with the installed gdal on install
> (via crssync). So it doesn't depend on qgis itself, but the installed GDAL.
GDAL 2.0 ships with EPSG 8.5. The latest version on the EPSG site is 8.7
> Jürgen
http://www.spatialys.com
