[Qgis-user] How to convert ECW using open source packages into something else?
Enrique
filonio at gmail.com
Tue Aug 4 14:29:48 PDT 2015
As recommended by Paul Ramsey, tiled schema is a better option, so I add it
to gdal_translate command.
Thanks!
a. Reading ECW and compressing to JPG (set your favourite quality, 80 is a
good choice for orthoimages; also CACHEMAX could be increased):
gdal_translate --config GDAL_CACHEMAX 1000 --config GDAL_PAM_ENABLED NO -of
GTIFF -co COMPRESS=JPEG -co TILED=YES -co JPEG_QUALITY=80 -co
PHOTOMETRIC=YCBCR "source_image.ecw" "target_image.tif"
b. Adding internal pyramids/overviews with JPG compression (select your
resampling method, I prefer average):
gdaladdo --config COMPRESS_OVERVIEW JPEG --config PHOTOMETRIC_OVERVIEW
YCBCR --config INTERLEAVE_OVERVIEW PIXEL -r average "image.tif" 2 4 8 16 32
64 128
2015-08-04 17:23 GMT+02:00 Steve Golden <stevenlgolden at gmail.com>:
> If you have access to Windows XP and can install GDAL, gdal_translate is
> the
> way to go to convert ECW to something else and GeoTIFF should be on your
> list for that something else. There are a lot of webpages out there with
> sample gdal_translate commands, but I recommend reading about GeoTIFF
> compression
> http://blog.cleverelephant.ca/2015/02/geotiff-compression-for-dummies.html
> from a very good source.
> -Steve
> http://osgeo-org.1560.x6.nabble.com/How-to-convert-ECW-using-open-source-packages-into-something-else-tp5218390p5218484.html
> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150804/53cad8ae/attachment.html>
