[Qgis-user] How to convert ECW using open source packages into something else? [ANSWERED]
Simon Cropper
contact at simonchristophercropper.com
Tue Aug 4 16:44:39 PDT 2015
Thanks everyone.
I got the message "GeoTiff is the preferred alternative file format to
ECW and gdal on Windows the method of converting the ECW to GeoTiff".
It's lucky I still have access to a Windows machine :-D but wonder what
I would do if I only had access to Linux :-\
Again, thanks for the timely responses
On 05/08/15 07:29, Enrique wrote:
> As recommended by Paul Ramsey, tiled schema is a better option, so I
> add it to gdal_translate command.
> Thanks!
> a. Reading ECW and compressing to JPG (set your favourite quality, 80
> is a good choice for orthoimages; also CACHEMAX could be increased):
> gdal_translate --config GDAL_CACHEMAX 1000 --config GDAL_PAM_ENABLED
> NO -of GTIFF -co COMPRESS=JPEG -co TILED=YES -co JPEG_QUALITY=80 -co
> PHOTOMETRIC=YCBCR "source_image.ecw" "target_image.tif"
> b. Adding internal pyramids/overviews with JPG compression (select
> your resampling method, I prefer average):
> gdaladdo --config COMPRESS_OVERVIEW JPEG --config PHOTOMETRIC_OVERVIEW
> YCBCR --config INTERLEAVE_OVERVIEW PIXEL -r average "image.tif" 2 4 8
> 16 32 64 128
> 2015-08-04 17:23 GMT+02:00 Steve Golden <stevenlgolden at gmail.com
> <mailto:stevenlgolden at gmail.com>>:
> If you have access to Windows XP and can install GDAL,
> gdal_translate is the
> way to go to convert ECW to something else and GeoTIFF should be
> on your
> list for that something else. There are a lot of webpages out
> there with
> sample gdal_translate commands, but I recommend reading about GeoTIFF
> compression
> <http://blog.cleverelephant.ca/2015/02/geotiff-compression-for-dummies.html>
> from a very good source.
> -Steve
> http://osgeo-org.1560.x6.nabble.com/How-to-convert-ECW-using-open-source-packages-into-something-else-tp5218390p5218484.html
> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> Qgis-user mailing list
> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
Cheers Simon
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150805/62b69de2/attachment.html>
