[Qgis-user] QGIS 2.10.1 adding PostGIS Views
Jürgen E. Fischer
jef at norbit.de
Thu Aug 6 11:58:11 PDT 2015
Hi Randal,
On Thu, 06. Aug 2015 at 13:53:08 -0400, Randal Hale wrote:
> In 2.8.x I can add the view and the Primary key is automatically displayed.
No, you're supposed to select the primary key. In 2.8.x you also have to
choose from all columns, but first one is preselected. If that happens to be
the primary key, you're fine, but that's not always the case and hence
newer versions force you to actually select it.
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
QGIS release manager (PSC) Germany IRC: jef on FreeNode
Desc: Digital signature
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150806/526ae35a/attachment.sig>
