[Qgis-user] Running QGIS in Citrix - plugin issues
McDonaldR
McDonaldR at angus.gov.uk
Fri Aug 7 08:39:58 PDT 2015
Hello list,
Maybe some of you can help me out. We're running QGIS 2.8.3 (64bit) in a Citrix XenApp 6.5 environment. I have installed the pgRouting layer plugin and can configure it to use my pgRouting network and I can get as far as clicking the RUN button when I get an error:
[Could not load library "D:/PostgreSQL/9.2/lib/librouting.dll". The specified procedure could not be found.]
If I run QGIS on my PC the plugin works correctly.
Somehow the Citrix environment is blocking access to the pgRouting libraries installed with the PostgreSQL database. Oddly, it seems to have worked out where the libraries are installed. Citrix configuration?
Is it a plugin configuration issue?
Thanks
Ross
Ross McDonald | GIS Data Coordinator | Resources Department, IT Division | Angus Council, Angus House, Orchardbank Business Park, Forfar, DD8 1AT
T: 01307 476419 | F: 01307 476401 | E: mcdonaldr at angus.gov.uk<mailto:mcdonaldr at angus.gov.uk>
This message is strictly confidential. If you have received this in error, please inform the sender and remove it from your system. If received in error you may not copy, print, forward or use it or any attachment in any way. This message is not capable of creating a legal contract or a binding representation and does not represent the views of Angus Council. Emails may be monitored for security and network management reasons. Messages containing inappropriate content may be intercepted. Angus Council does not accept any liability for any harm that may be caused to the recipient system or data on it by this message or any attachment.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150807/d427acee/attachment.html>
