[Qgis-user] Georeferencing Vector Files
Alex Mandel
tech_dev at wildintellect.com
Sat Aug 8 12:07:18 PDT 2015
On 08/06/2015 11:08 AM, Springfield Harrison wrote:
> Hello All,
> Is there a tool/plugin for georeferencing vector files to an existing
> projected layer?
> I'm intending to bring in property survey drawings that have only local
> coordinates but projected coordinates (UTM) are available for some corners.
> Thank you . . . .
> Cheers . . . . . Springfield Harrison
> Samsung Tab 4
My trick, is convert the vector an image in QGIS (Save Image)
Georeference the image, saving the control point list out to a file.
You can then use these control points (gcps) with ogr2ogr to transform
the original vector.
-Alex
