[Qgis-user] Georeferencing Vector Files
Springfield Harrison
stellargps at gmail.com
Sat Aug 8 19:22:20 PDT 2015
Hello Alex,
This sounds promising, but then so did the other plug-ins.
Where do I find the OGR2OGR functionality? I found some
help information referring to it but nothing about how it is accessed.
Not sure why I would need to create the control points from
the raster georeferencing as I already have them from fieldwork or
other sources. What I do need is a function or tool to rubber sheet
the un-projected coordinate list onto a projected layer containing
the control points.
My CAD program is not able to do this. I tried manually
shifting and rotating but that is a very sketchy process at best. My
testing so far indicates that the transformation to UTM will require
both scaling and rotating.
Thank you, Cheers . . . . . . . . Spring Harrison
At 08-08-2015 12:07 Saturday, Alex Mandel wrote:
>On 08/06/2015 11:08 AM, Springfield Harrison wrote:
> > Hello All,
> > Is there a tool/plugin for georeferencing vector files to an existing
> > projected layer?
> > I'm intending to bring in property survey drawings that have only local
> > coordinates but projected coordinates (UTM) are available for some corners.
> > Thank you . . . .
> > Cheers . . . . . Springfield Harrison
> > Samsung Tab 4
>My trick, is convert the vector an image in QGIS (Save Image)
>Georeference the image, saving the control point list out to a file.
>You can then use these control points (gcps) with ogr2ogr to transform
>the original vector.
>-Alex
