[Qgis-user] QGIS & Spatialite: problem with renewed views
Andrea Peri aperi2007 at gmail.com
Sun Aug 9 08:51:55 PDT 2015
Hi xof,
you are using a gis project ?
I guess more probably the explanation could be the qgis that save the
fields name and alias in the project.
If you try to start a new project this happened however ?
A.
2015-08-09 17:41 GMT+02:00 X Of <xof.biz at gmail.com>:
> Dear List
> In spatialite, if I renew a view (drop a view and recreate it under the same
> name but with different content/fields), QGIS somehow is not adapting to
> this new situation. I am not able to re-import the new view as a layer to
> QGIS (well, I'm able to re-import, but QGIS only shows the fields that have
> been present in the previous version of the view, that got dropped).
> In the db-manager everything is looking good - I can "manually" query the
> renewed view just fine.
> I've tried to also delete the view from the views_geometry_columns-table and
> re-insert it there - QGIS still doesn't recognize the new view.
> My only workaround so far ist to create the new view under a slightly
> different name each time (testview2, testview3, testview4...).
> Any help on this topic is highly appreciated..
> Thank you!
> Qgis-user mailing list
Andrea Peri
qwerty àèìòù
