[Qgis-user] Modeler-only tools: Calculator
Bernd Vogelgesang
bernd.vogelgesang at gmx.de
Mon Aug 10 06:07:20 PDT 2015
Hi Andy,
I already tried that way: Created a small model, made changes, and used
diff to see the relevant changes.
Manually removed them. That works.
Doing the same in my bigger model: Crash!
No idea, there must some extra voodoo with those files.
Cheers
Bernd
Am 10.08.2015, 14:42 Uhr, schrieb Andrew Harfoot
<ajph at geodata.soton.ac.uk>:
> On 09/08/2015 15:07, Bernd Vogelgesang wrote:
>> There seems to be no way to get rid of that function from the model
>> manually in a text editor, identifying the section and removing it still
>> leaves a crippled model which refuses to load.
>> Questions:
>> Is there anyone around who is able to explain me the structure of a
>> model
>> file or point to least some minimal documentation?. Why do nearly every
>> manual operations on a model in an editor destroy them, and how can I
>> avoid this?
> Hi Bernd,
> I would suggest building and saving a simple model with a Calculator
> included, and then removing it, saving a copy of the file, and looking
> at a diff between the before and after model files, that way you should
> get a better idea of the model file structure and hopefully some
> pointers to repairing your original model!
> Cheers,
> Andy
Bernd Vogelgesang
Siedlerstraße 2
91083 Baiersdorf/Igelsdorf
Tel: 09133-825374
