[Qgis-user] Georeferencing Vector Files
Springfield Harrison stellargps at gmail.com
Mon Aug 10 09:24:28 PDT 2015
Good news!  I've struggled with the mapset idea and gave up.   Actually, it
was the Group thing that finished me off.
I'll look again in the processing tool box, I don't remember seeing it.
I just (re)installed 2.10 but options seem  to  come and go at random.  For
me, QGIS is great but all the install failures and missing dependencies
have put me off.   I've tried many plugins that won't run.
Thanks . . .
Cheers . . . . .   Spring
Samsung Tab 4
On Aug 10, 2015 3:27 AM, "Thomas Colley" <it087 at neath-porttalbot.gov.uk>
wrote:
> Hi
> I did this recently using the GRASS command v.transform.pointsfile from
> the Processing Toolbox in QGIS. No need to actually go into GRASS and
> create mapsets.
> This worked really well for me for unreferenced DXFs. If you need any more
> info let me know.
> Cheers
> Tom
> -----Original Message-----
> From: qgis-user-bounces at lists.osgeo.org [mailto:
> qgis-user-bounces at lists.osgeo.org] On Behalf Of Springfield Harrison
> Sent: 09 August 2015 19:51
> To: tech at wildintellect.com; qgis-user
> Subject: Re: [Qgis-user] Georeferencing Vector Files
> Ok, thanks.  I'm installing QGIS on W7 yet again, trying to achieve better
> functionality.  That is a challenge in itself, prone to wrong turns.
> Hopefully the VectorGeoref will then work.
> This whole install process is a real piece of work . . . . .
>                  Thanks again, cheers . . . .   Spring Harrison
> At 09-08-2015 10:52 Sunday, Alex Mandel wrote:
> >ogr2ogr is a command line tool, Terminal/Shell on Mac/Linux, OSGeo4w
> >shell on Windows.
> >Supposedly the Vector Georef plugin wraps this functionality into QGIS.
> >-Alex
> >On 08/09/2015 12:08 AM, Springfield Harrison wrote:
> > > Right, but where is org2org? I've looked in many menu items, help, etc.
> > > to no avail.
> > > Sorry to be a bit thick but how is it accessed?
> > > Also, GRASS has v.transform and v.rectify but starting a new GRASS
> > > mapset fails with no reason given.
> > > Great tools but why are they so hard to access?
> > >        Thanks, cheers . . . .  Spring Harrison
> > > At 08-08-2015 23:20 Saturday, Alex Mandel wrote:
> > >> Save the whole map, it's on the main File menu, it just saves the
> > >> current canvas.
> > >> If you already have a list of gcps you can skip that step
> > >> Example
> > http://gis.stackexchange.com/questions/107298/process-to-georeference-
> > corners-of-vector-file
> > >> Enjoy,
> > >> Alex
> > >> On 08/08/2015 07:26 PM, Springfield Harrison wrote:
> > >> > Hello Alex,
> > >> >       Further to my last, for Vector Save As, I couldn't find any
> > >> > option to save it as a raster file. Is there some other place to
> look?
> > >> >               Thanks again, Cheers . . . . . . . . Spring
> > >> > Harrison
> > >> > At 08-08-2015 12:07 Saturday, Alex Mandel wrote:
> > >> >> On 08/06/2015 11:08 AM, Springfield Harrison wrote:
> > >> >> > Hello All,
> > >> >> > Is there a tool/plugin for georeferencing vector files to an
> > >> existing
> > >> >> > projected layer?
> > >> >> > I'm intending to bring in property survey drawings that have
> > >> >> > only
> > >> local
> > >> >> > coordinates but projected coordinates (UTM) are available for
> > >> >> > some
> > >> >> corners.
> > >> >> > Thank you . . . .
> > >> >> > Cheers . . . . . Springfield Harrison Samsung Tab 4
> > >> >> My trick, is convert the vector an image in QGIS (Save Image)
> > >> >> Georeference the image, saving the control point list out to a
> file.
> > >> >> You can then use these control points (gcps) with ogr2ogr to
> transform
> > >> >> the original vector.
> > >> >> -Alex
> > >> > _______________________________________________
> > >> > Qgis-user mailing list
> > >> > Qgis-user at lists.osgeo.org
> > >> > http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150810/176a14b2/attachment.html>
