[Qgis-user] Georeferencing Vector Files
Paolo Cavallini
cavallini at faunalia.it
Mon Aug 10 10:32:17 PDT 2015
Hi.
I have a different experience. Please report the issues you encountered, that's the first step to fix them.
All the best.
Il 10 agosto 2015 18:24:28 CEST, Springfield Harrison <stellargps at gmail.com> ha scritto:
>Good news! I've struggled with the mapset idea and gave up.
>Actually, it
>was the Group thing that finished me off.
>I'll look again in the processing tool box, I don't remember seeing it.
>I just (re)installed 2.10 but options seem to come and go at random.
>For
>me, QGIS is great but all the install failures and missing dependencies
>have put me off. I've tried many plugins that won't run.
>Thanks . . .
>Cheers . . . . . Spring
>Samsung Tab 4
>On Aug 10, 2015 3:27 AM, "Thomas Colley"
><it087 at neath-porttalbot.gov.uk>
>wrote:
>> Hi
>> I did this recently using the GRASS command v.transform.pointsfile
>from
>> the Processing Toolbox in QGIS. No need to actually go into GRASS and
>> create mapsets.
>> This worked really well for me for unreferenced DXFs. If you need any
>more
>> info let me know.
>> Cheers
>> Tom
>> -----Original Message-----
>> From: qgis-user-bounces at lists.osgeo.org [mailto:
>> qgis-user-bounces at lists.osgeo.org] On Behalf Of Springfield Harrison
>> Sent: 09 August 2015 19:51
>> To: tech at wildintellect.com; qgis-user
>> Subject: Re: [Qgis-user] Georeferencing Vector Files
>> Ok, thanks. I'm installing QGIS on W7 yet again, trying to achieve
>better
>> functionality. That is a challenge in itself, prone to wrong turns.
>> Hopefully the VectorGeoref will then work.
>> This whole install process is a real piece of work . . . . .
>> Thanks again, cheers . . . . Spring Harrison
>> At 09-08-2015 10:52 Sunday, Alex Mandel wrote:
>> >ogr2ogr is a command line tool, Terminal/Shell on Mac/Linux, OSGeo4w
>> >shell on Windows.
>> >Supposedly the Vector Georef plugin wraps this functionality into
>QGIS.
>> >-Alex
>> >On 08/09/2015 12:08 AM, Springfield Harrison wrote:
>> > > Right, but where is org2org? I've looked in many menu items,
>help, etc.
>> > > to no avail.
>> > > Sorry to be a bit thick but how is it accessed?
>> > > Also, GRASS has v.transform and v.rectify but starting a new
>GRASS
>> > > mapset fails with no reason given.
>> > > Great tools but why are they so hard to access?
>> > > Thanks, cheers . . . . Spring Harrison
>> > > At 08-08-2015 23:20 Saturday, Alex Mandel wrote:
>> > >> Save the whole map, it's on the main File menu, it just saves
>the
>> > >> current canvas.
>> > >> If you already have a list of gcps you can skip that step
>> > >> Example
>http://gis.stackexchange.com/questions/107298/process-to-georeference-
>> > corners-of-vector-file
>> > >> Enjoy,
>> > >> Alex
>> > >> On 08/08/2015 07:26 PM, Springfield Harrison wrote:
>> > >> > Hello Alex,
>> > >> > Further to my last, for Vector Save As, I couldn't find
>any
>> > >> > option to save it as a raster file. Is there some other place
>to
>> look?
>> > >> > Thanks again, Cheers . . . . . . . . Spring
>> > >> > Harrison
>> > >> > At 08-08-2015 12:07 Saturday, Alex Mandel wrote:
>> > >> >> On 08/06/2015 11:08 AM, Springfield Harrison wrote:
>> > >> >> > Hello All,
>> > >> >> > Is there a tool/plugin for georeferencing vector files to
>an
>> > >> existing
>> > >> >> > projected layer?
>> > >> >> > I'm intending to bring in property survey drawings that
>have
>> > >> >> > only
>> > >> local
>> > >> >> > coordinates but projected coordinates (UTM) are available
>for
>> > >> >> > some
>> > >> >> corners.
>> > >> >> > Thank you . . . .
>> > >> >> > Cheers . . . . . Springfield Harrison Samsung Tab 4
>> > >> >> My trick, is convert the vector an image in QGIS (Save Image)
>> > >> >> Georeference the image, saving the control point list out to
>a
>> file.
>> > >> >> You can then use these control points (gcps) with ogr2ogr to
>> transform
>> > >> >> the original vector.
>> > >> >> -Alex
>> > >> > _______________________________________________
>> > >> > Qgis-user mailing list
>> > >> > Qgis-user at lists.osgeo.org
>> > >> > http://lists.osgeo.org/mailman/listinfo/qgis-user
Paolo Cavallini
http://www.faunalia.eu
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150810/cf73b6f6/attachment.html>
