[Qgis-user] Where can I get a shapefile made from a table of co-ordinates to map a bird monitoring project ?
Stefan Kiefer st_kiefer at web.de
Tue Aug 11 00:28:07 PDT 2015
Hi Stephen,
you can import the textfile directly to QGis (layer-->add layer-->import
textfile). Afterwards you can save the layer as shapefile (layer-->save as)
(Shapefile is default).
The file should be like:
x,y
1,2
2,3
3,4
if you have other column names you have to set the correct column for
coordinates in the import dialog!
cheers
Stefan
> Stephen Routledge <rout at netc.net.au> hat am 11. August 2015 um 09:09
> geschrieben:
>  Dear Qgis list,
>  I have a data base with 11 fields with 52 eastings and northings which I
> would like to map.
>  Where can I get a shape file made to fit my QGIS 2.8 WIEN software OS X
> 10.8.5 operating system. (EPSG :4326, WGS 84)
>  Can anyone please help? I have been struggling with this for a week and my
> brain has come to a brick wall….
>  Any easy solution and a nudge in the right direction would be much
> appreciated.
>  Yours sincerely
>  Stephen Routledge
>  Project Manager
>  Swamps Rivers & Ranges
>  0467224124
>  http://swampsriversandranges.org/
>  Qgis-user mailing list
>  Qgis-user at lists.osgeo.org
>  http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150811/a9134348/attachment.html>
